How can I capture directly to mpg with this card. I have looked around and the best i can get is m2p which will not play on any player I have. I then have to re-encode it with TMPGEnc to get it to a real MPG. Any ideas? Any software recommendations?
Thanks in advance
Bob
Either:
1. rename the .mp2 to .mpg
2. Use MMC 7.7: it will capture MPEG2 with the correct .mpg extension
3. Edit your recording preset and change the compression to MPEG1 -
Bobm67
MMC7.7 stands for MultiMedia Center Ver. 7.7 You don't need to worry about it unless you have an ATI card. It is specially written by ATI for their cards and will not work with other brands.
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11
