i have not seen this post yet...
when i use flask mpeg, and try to choose a low bitrate so i could fit an entire movie onto a 700mm cd, flask ends up adding like 100 to 200 MBs onto the resulting mpg. yet, if i were to de-mux the file with tmpg, the vid and audio files are the exact size that i had calculated out. then if i mux those two, tmpg says there's sync errors, file might play bad...blah blah.
okay to clarify the above a little bit, this what i've been trying to do: I've got happy gilmore ripped to the hd. it's an 88 minute movie, so i calculated that i could afford a constant bit rate of about 1000kbps for vid + audio.
in flask, i use the bbmpg encoder, and in that thing, i set the constant bitrate as 900000, with 64bps for the audio - a total of 964kbps, which should be fine: 964*60*88/8000 = 636MB. but guess what, the file ends up being over 800MBs. WTF is happening here? any suggestions out there?
I'm not entirely sure what you've done wrong, but here's a few pointers.
1. The VCD bitrates are fixed at 1150 kbit/s for video and 224 kbit/s for audio. Anything else is XVCD (i.e., non-standard).
2. 64 kbit/s for MPEG-1 Layer 2 audio (which is what VCDs use) is LOW, LOW, LOW. Your audio quality will be quite poor. If you are going to make XVCDs, I suggest that you at least use 128 kbit/s and up.
3. 700MB/80min CDs can fit 80min or about 800MB of MPEG video on a disc. VCDs burn in MODE2 Form2 and the apparent increase in capacity is due to the fact that additional error correction codes (which are used for ordinary CD-ROMs) are used.
Regards.
Michael Tam
w: Morsels of Evidence -
oh let me clarify one other thing, i'm not trying to make a vcd out of this thing... i just wanted to be able to play a decent mpg on my computer. otherwise, i would use the normal vcd bitrates.
also, i don't really mess with any of the bbmpeg settings; i click "use floating point," mux audio, mux video, i click "mpeg 1", i set cbr as 900000, and i set audio as layer 2, 64kbps, i set fps to 29.97. and in the global settings for flask, i set "hq bicubic ...", 29.97fps, decode audio to 44khz. so other than this stuff, i don't mess with the other settings in bbmpeg, as i don't know what they are anyways. vitualis, or anyone, got any ideas here? thanx in advance...
best program for separating one large MPG file to several sequential files
By nplovernmi in forum EditingReplies: 3Last Post: 20th Aug 2011, 18:09 -
MPG files are too large
By sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 06:59 -
Very large MPG... how to process ?
By csc12345678 in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2010, 06:48 -
Large size difference in mov and mpg, no apparent loss of quality.
By prioryjim in forum Video ConversionReplies: 3Last Post: 20th Dec 2009, 10:19 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
