What the best guide for me to use to get the best quality dvdr? It doesn't matter how long it takes as long as it doesn't require a lot of ram (any more than 128mb i know its slow). I've heard CCE produces the best quality but I'm not familiar with it and most guides show how to do things with Tmpgenc because its the easiest. What's the best guide out there?
"Nothing is difficult, some things just take time"
Try the guide on dvd2dvdr.com This was the one I started with and still use. I have also heard about cce giving better results, but read a few guides which make my head spin, unless anyone can break it down simply for us
thanks, which guide?
"Nothing is difficult, some things just take time" -
I would try the spruce guide first. that is the one i use with no probs. i am going to be trying the ifoedit one next !! will let you know
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
How to save Re:Quality guide for HTPC, how to configure MPC-HC, ffdshow, et
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2011, 08:09 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
StaxRip Guide-w-Templates for High Quality XviDs
By Trac in forum User guidesReplies: 0Last Post: 24th Jul 2007, 01:53
