Startet some serious work with vcd2tk, to author a VCD with menues, background sound and some navigation. Volume 1 of a set of 2 worked fine.
With volume 2 the chapter entries are partly completely wrong with a difference of many minutes of the original chaptermark and the realised, not only the usual few frames.
found that by playing on a CDI-220 and also by analysing with vcddebug.
For coding the MPEG I used TmpegEnc 2.5, separate streams for video (1-4-2, no scene detect) and audio, muxed the thing with VCDMUX. No complaints by this and vcd2tk, but the result is disappointing (after all that work).
All the rest works fine, anybody a clue ?
Peter
I found this happened using tmpgenc with the vcd toolkit. I was able to use other encoders and they worked fine. I think it is just a very subtle bug in tmpgenc. The vcd toolkit is very, very strict about it's compliance.
Thanks for the reply.
Which one do you use ?
How about the quality of those, TmpegEnc is absolutely fine ?
Peter
Pioneer DV 585a playing several new movies in wrong chapter order.
By snirpens in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Apr 2012, 13:52 -
Why TWO M-JPEG codec entries?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2009, 16:38 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Mass Deleting Registry Entries
By mysts in forum ComputerReplies: 8Last Post: 28th Apr 2008, 08:57
