Hello,
Captured to MPEG2 high setting with neodvd 4.Followed instructions to convert to SVCD with TMPGENC and succeed often. However sometimes tmpgenc freezes at certain places in the encoding part and the fixes regarding enviroment settings and wav do not always work. I looked to repair the MPEG2 and tried MPEG Corrector but when I feed in the results to tmpgenc I get "illegal mpeg stream". Are there any other ways of repairing? . I have seen about remuxing and using the resulting as new mpg?
PS Tried iuVCR as a way of capturing to avi and got poor quality capture/preview (like playing a very worn vhs tape). Any ideas as I am looking to find/deal with bad frames other than using Vdub due to WDR drivers and win 98?
PPS neodvd blurb says captures to avi,mpeg 1 and 2. So where`s the avi??
The Program does not produce proper MPEG headers. I did run into similar problems before.I hated this program.I will never use it again
High Quality Encoding AVI -> MPEG2
By vl0001 in forum MacReplies: 2Last Post: 21st Jan 2012, 09:40 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 13:16 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 18:14 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 16:06 -
how to play high definition mpeg2 on HDTV
By edong in forum Newbie / General discussionsReplies: 4Last Post: 11th Mar 2008, 12:49
