HEY
I looked evrywhere for the HKEY file that was suppose to fix the XP problem ( under newbie ) I just can't find it. could someone draw a picture to where it is ????
Please
THANKS
You need to be more specific about your problem if you want help. There's a lot of "XP problems" and "HKEY files". If you're looking for the key that allows you delete/move AVIs in XP, look here:
http://www.vcdhelp.com/forum/viewtopic.php?t=100406&highlight=delete
Otherwise give more details or use the Search function.
Regards. -
Sorry
I mean the xp fix with avi's that is in the begining of newbie'a
i am suppose to find a file named : HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D9 4-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32
i have no idea where to find this file, that i am suppose to delete !!!
does this help or do you need more info. ???
Thanks -
On your desktop:
Click Start
Go to Run...
Type regedit
Press OK
Find folder InProcServer32 and delete it (or better export it to your desktop before deleting it in case you want to import it later). -
T H A N K Y O U
It is so easy when you know how !!!!!!
This is for moving or deleting avi files in XP
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 17:41 -
30 stupid inventions
By deadrats in forum Off topicReplies: 2Last Post: 18th Feb 2010, 23:38 -
i know this sounds stupid but...
By cthuggha in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th May 2009, 09:02 -
Probably a stupid question, BUT...
By HmNtr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Dec 2008, 12:22 -
New to burning: Am I stupid?
By Eat Right in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2008, 12:47
