Page 17 of 43
FirstFirst ... 7 15 16 17 18 19 27 ... LastLast
Results 481 to 510 of 1282
  1. @NYPlayer
    ouch, thats a big blow...kinda takes the whole use out of using this program for the time being i guess =/
    So this problem wont be resolved until ifoedit has been fixed then?
    Thanks for the help, i'll give dvd maestro a shot and will post my results.
  2. Originally Posted by beatnitup
    @NYPlayer
    Actually the program is very useful, it automates almost the entire process, except the authoring part, but DVD Maestro is very easy to use and does a great job (I don't worry about the subtitles so I can't speak on that matter).
  3. can someone please tell me what the drop frame flag does???
    i havent been using it.....since i have no idea what it does
    Bond..........James Bond
  4. Following the advice that was just given to use dvdmaestro.....I am in the midst of trying it. I loaded the chapter list from the original dvd but when I go to load it into dvdmaestro it says "I-frame insertion entry frame is not consistent with tape frame rate! Any ideas?
  5. @Damnit
    Thanks for the info, i've been trying to find DVD Maestro but have had no luck so far =/
  6. I have two questions total and then I think I have this down....YEAH! The first, I just asked and that is how do I get the chapters in (see my question before this one) and the second is how do I get it to show up as widescreen. The film is originally wide screen, but it has become elongated in this last try. Any help would be greatly appeciated. Thanx in advance
  7. @ozzie.
    I You look right the above the the Real View window you will see 4:3 you can right click on it and set it to 16:9 ls/ps
    On the Chapters right before I open the original ifo to extract my chapters using chapterxtractor i make a minor change.
    I select presets for DVDmaestro then I make a change to the format.
    I change the colon after %ss and before %ff to a semicolon. Then I open that original ifo and save my chapters.
    %hh:%mm:%ss;%ff\n
  8. @Chatwalker
    Congrats for an ass kicking cool prog.
    Been following the 13 pages of posts since first downloading the version. Thought it might be usefull to explain how things have been working for me.
    All NTSC backups for me. Never had any luck authoring with ifoedit until I recently updated the firmware on my HP DVD 200e. (No idea where to get DVDMaestro so ifoedit is really my only option.) Now rather then random freezes, I can consistently view movies on my standalone up to about 1:40 in length. After that my standalone just stops playing the movie. This is an issue with any dvd I backup (same w/ DVDDecrypter) so can't really explain what's going on.
    I have a feeling I must be doing something wrong still with my DVD backups in general. The only perfect copies I have made are with DVDXCopy, yet don't want to waste 2 disks on each movie.
    Info:
    XP SP1
    HP DVD 200e
    Memorex DVD+RW
    Sony DVP-NS315
    Always use force film,
    now set DropFlag (although don't know what it does)
    no expert-mode (don't know what that does either)
  9. @NYPlayer
    I do believe you rule. That looks like its gonna work for me. chapters loaded up fine after that and I found the place to change it to letterbox. thanx for all your help. This program rules. Very important to have the right software for all those still struggling. Follow the directions for turning off authoring in DVD2DVDR and what you need to select on page 12 of this post I believe. Then follow on this page some important details for Spruce Maestro and walla. Thanx again.
  10. One last question....would this wor for changing a PAL dvd to NTSC?
  11. Originally Posted by NYPlayer
    %hh:%mm:%ss;%ff\n
    Thanks for this bit of info, I have ran into some problems with the chapters, but could never figure out what the heck to do and eventually just said the heck with it. What exactly does changing the colon to a semicolon do (besides the obvious of course).
  12. Quick Question :- Why don't you just use DVD2DVDR's Scenarist mode to author the DVD as DVD2DVDR creates the scenarist script for you, all you need to do is load it into Scenarist. It automatically loads the re-encoded video, sets chapter points, imports all the audio tracks etc. Then you just click burn. Easy way to get around the NTSC Ifoedit problem.
    The only thing it doesn't do is subtitles but they can be ripped easily enough with subrip if you require them
  13. Tried scenarist it will not import the Video keep getting an error. This is of course on NTSC films.
  14. Upper Field First -
    For NTSC, I believe the proper protocal for this is to leave it unchecked
    _unless_ BitRateViewer says it is NOT Upper Field First
    (due to a 'bug' in CCE).
    If you are wrong, however, you can run Pulldown to switch them and
    don't have to start the process over again. (I think the format is
    pulldown old.file new.file -nopulldown -tff [odd,even] - were odd/even
    are the parameters).
    Can one of the sages on this list confirm the last two, I have been inside
    and out this site and Doom9's for definitive answers to basic questions....
    Will
  15. Hi
    I have a problem ripping Disney's Atlantis , the main movie is
    located in Vts 12 - Pgc 2 , But when i try to rip the movie , it came out with a lot of bad audio frames
    What does Dvd2dvdr do , when it checks the audio file ?
    What will happen if i take the audio file that haven't been checked
    and author it with the rest of the movie ?
    will there be a problem with sound or a sync problem ?
    How to rip it without the problems ?
    Please help me
    Regards
    Klampe
  16. The first two DVD's worked great, but now DVD2DVD-R hungs at the end of CCE encoding and I'm not even sure that he did it fully. I tested by erase the log files in DVD2DVD-R but same prob.
    [-Neoh*-]|[-Cheers-]
  17. Originally Posted by NYPlayer
    Did you run pulldown on the .M2V before importing the video as it needs to be at the correct framerate
  18. I'm having problem again. Started having trouble when had to uninstall the program and re-installed it.
    1) I could not get the Pulldown to work.
    2) Then, I it did the long process of re-encoding, but when CCE was finished it just stopped.(Had to manually close out program.)
    I have successfully made 2 backups before. I'm thinking that I am not install the program right. I think that I got lucky on the first install. Does anyone have a correct way to install the program.
    Is there installer icon or do I have to click ever (exe icon) or just the setup icon or the CD icon?
    Does anyone have a quick setup guide.
  19. @Merciless:
    You are not doing something wrong...
    This version, 1.3.4, has a bug. Sometimes it finish all process, and sometimes it stops after encoding. I think that Chatwalker knows the problem and is working on it.
    Give some mantainance to your computer (Desfragment HD, clean registry, etc). That works for me...
    Antonio S.
  20. @Antonio S.
    Thanks,
    I first had 1.30 then I decided to try 1.3.4. Should I try to go back to an older version like 1.3.2 or 1.3.3.
  21. I go threw the whole process of waiting 4.5 hours and Pulldown fails. Can someone tell me why this is not working correctly. Pulldowne.exe icon is in the DVD2DVDR folder.
    This is driving me crazy.
    Is there away for me to continue the Pulldown process? I have GUI Pulldown, but I do not know how to use it.
    Really could use some help.
  22. Originally Posted by NYPlayer
    %hh:%mm:%ss;%ff\n
    This is one way to do it but when you chose the file format in Chapter Xtractor for DVDMaestro, it is the correct format.
    You need to configure the "Chapter Marker Properties" in Maestro. Do the following:
    1. There is a step that needs to be done before you import the chapters list. Right click on the Chapter timeline and select PROPERTIES instead of "Import Chapter List".
    2. In the "AUTO-NAME" section select INDEXED BASED. Then click OK.
    3. Now import your chapter list.
    For complete instructions on configuring and using Maestro may I suggest reading the following GUIDES:
    Spruce DVDMaestro
    http://www.doom9.org/index.html?/mpg/maestro.htm
    FukHead's Maestro Unleashed
    http://www.fukrulez.com/modules.php?name=Content&pa=showpage&pid=11
    DVD2DVDR
    http://digital-forums.com/dvd2dvdr/intro.htm
    This last guide is not to be confused with the GREAT software DVD2DVD-R by Chatwalker that is topic is all about!
  23. joepic
    That does not work for me at all. The way I do it works everytime. Remember I am Doing NTSC with pulldown and Set Drop Frame.
    BTW I am ver familar with the guides and have read them.
  24. Anybody know if there is a way to make this package work for converting PAL to NTSC????
  25. @NYPLAYER
    what does the set drop frame do???
    i do everything the same way but i do no use that.......
    Bond.......James BOnd
  26. @merciless
    i use this pulldown frontend at link below i don't touch any settings just process the old file into a new one and the 4 discs i have done so far has been fine.
    http://guiguy.wminds.com/downloads/pulldownbatchfe
  27. Originally Posted by klampe
    Hi
    Please help me
    Regards
    Klampe
    It is not the soft, it is the DVD it self, I have the same problem, the only track I can get correctly is the french one.
  28. Member
    Nov 2002
    Greece
    @ Neoh & Klampe:
    1. Rip using DVD2SVCD's internal routines or Vstrip (in the program).
    DO NOT use Decrypter nor SmartRipperwhen using this method.
    2. Open ripped ifo with ifoedit and write down numbers of Audio tracks and subs.
    3. Make new IFO. Correct subtitle colours.
    4. Make image using IFOEDIT.
    5. Mount image using Daemon tools
    6. Start DVD2DVDR, check the numbers of Audio and subs you want, and you should have no problems.
    OR
    1.Rip-decode using DVD2SVCD's internal routinesand DVD settings.
    2.Use ChapterXtractor for chapters
    3.Subrip for subs
    4.Use Maestro to encode
    I love DVD2DVDR and I really hope Chatwalker can iron out all the bugs, but DVD2SVCD is my first love and has got me out of really difficult and head-banging-on-the-wall situations.
    I always try new ways to do DVDRs, but if everything fails, I know DVD2SVCD will get me out.
    PLUS it's the only one that gets me those ^%$#* STNG DVDs without much hassle.
  29. Bond8089,
    The set frop frame flag. I use it to make sure subtitles are in the right place.
    see thread for more info
    http://forum.doom9.org/showthread.php?s=2b87e34a012982b86fd74d859797ef7e&threadid=2483...dropframe+flag
