thanks clairehoward, I already found a link that works. Unfortunately, I'm still having the same problem as I stated above. I can't figure out what's wrong with it. Hopefully someone can solve this one for me. I will keep thinking.
If you have any more ideas or suggestions, I started a post called "problem with dvd2dvdr" in this same forum, you can look there for more details of what is wrong. Thanks everybody.
Results 601 to 630 of 1282
Which version of this software is everyone finding is the best to be using on win2k?
Depends if you are doing NTSC or PAL movies... I have had the best luck with 1.32 1.33 and 1.34 seem to be buggy >>> Just my two yet...Mighty.
Just got version 1.3.5, going to give it a spin, post my results later.
www.dvd2dvd-r.de
Frenetic -
Originally Posted by Frenetic24
Ver 1.3.5 [18.01.2003]
- Timestamp-Bug in Subtitles fixed
- wrong Audioindex-Bug fixed
- wrong Audiodelay-Bug fixed
- PCM-'File not found'-Bug fixed
- some additional small Bugfixes
- CCE-Control modified -
This new version, 1.3.5, has the same bug of other version: After encoding nothing happens...
Antonio S. -
Originally Posted by Antonio S.
Then I tried ifoedit mode, it did a pulldown and then authored the DVD. -
Vader443,
Ifoedit is not good to author DVD's that use pulldown its a well known bug. I too cannot import into Scenarist. I think its the way DVD2DVD-R is setting up CCE to encode NTSC Films, is the reason we can't import to scenarist.
This program is not good for NTSC at the moment unless you use DVDMaestro. -
I am doing NTSC and it sounds like the older versions work better for this....is that true? If so, could someone post a link to where I might find these older versions 1.3.2 or 1.3.3 or both...which ever works best for this...thanx
if you have to re-encode you loose quality. what is the assessment in terms quality loss?
Regards,
JDaCunha -
if you have to re-encode you loose quality. what is the assessment in terms quality loss?red red wine you make me feel so fine
The choice would be to split to 2 DVDs. Of course that costs you an extra 80 cents for DVD-R, and some people have a cow at the thought of switching.
I've found reencoding in CCE at near 4Mbs does an outstanding job. -
I used this software for the first time last night to backup a NTSC DVD. I have read thru this entire thread but I still do have a couple of questions:
1) How do you remove/delete a video asset from the timeline in DVDmaestro after you have imported your chapters? I read in an earlier post by ROBW that you need to highlight it then press delete, but I couldn't find the delete button.
2) After I compiled my DVD in DVDmaestro and burned it, the movie played fine but would not start up automatically. Did I miss a step?
3) Is the easiest way to figure out the settings for cce (Upper Field First/ Zig Zag/ Progressive) to use bitrateviewer. If so how reliable is this?
Thanks in advance
@gconrad2
1) press delete on your keyboard
2) remove the menu subsection part on left window next to where you add the video and audio
3)so far i have had no problems with movies using settings bitrate viewer has given me 99% of time dvd2dvdr is correct with the settings -
@Chatwalker.
There is a problem the way DVD2DVDR sets up the GOP structure for NTSC Films.
The Gop structure is too large when we encode and apply pulldown it won't import into scenarist.
This the way your program sets up CCE
gop_m=3
gop_nm=5
gop_hdr=15
seq_hdr=1
This is the way CCE needs to be setup for NTSC Films. Any Chance of getting some kind of change
so that we can fully utilize your program.
gop_m=3
gop_nm=4
gop_hdr=12
seq_hdr=1 -
@Chatwalker.
Thers is also a problem with the Scrip for Scenarist when doing NTSC Films.
Scenarist scripts problems.
The Drop Type=Non-drop frame is always the same even though I chose drop frame.
Data Format Version=4
Build Version=19980918
Edition Version=1000
Object=Data Folder
Name=Data
Data=List
Item=AC3 Audio
Place Holder=No
Comment=
Name=DVD2DVDR_Audio_1
Resolution=NTSC
Data Start Time=00:00:00;00
Data End Time=01:41:15;07
File=C:\EXIT_WOUNDS_21.01.2003_15.01\Checked_Audio _0x80_English.AC3
Audio Type=AC3
Bit rate=384000
Channel=3 : 2
LFE On=Yes
Bsmod=complete main
Item=AC3 Audio
Place Holder=No
Comment=
Name=DVD2DVDR_Audio_2
Resolution=NTSC
File=C:\EXIT_WOUNDS_21.01.2003_15.01\Checked_Audio _0x81_French.AC3
Audio Type=AC3
Bit rate=384000
Channel=3 : 2
LFE On=Yes
Bsmod=complete main
Item=Video
Place Holder=No
Comment=
Name=DVD2DVDR_Video
Resolution=NTSC
File=C:\EXIT_WOUNDS_21.01.2003_15.01\Video_0xE0_NE W.M2V
Width=720
Height=480
Is Encoded=Yes
Encode Type=MPEG 2
Size=720 x 480
Aspect Ratio=16 : 9
Picture Structure=Frame Structure
GOP Size=15 frames
GOP Structure=N/A
Bit rate=8000000
Average Bitrate=6000000
Minimum Bitrate=4000000
Bitrate Type=Variable
Icon Time=00:00:00;00
Line21 Switch1=No
Line21 File1=
Line21 Switch2=No
Line21 File2=
Chapter Breaks=List
Every time I get it to the point that it looks for CCE it can not find it, what am I doing wrong? The path that CCE is installed to is the default path, it is on the same partition that DVD2DVDR is installed to (NTFS), I will install the newest version of DVD2DVDR now then post back after all is done or I get the same error!
Thanks alot,
dreadogg -
You install CCE with the install program right?
If yes, try this in the following order:
Un-install DVD2DVDR
Un-install CCE 2.5
Re-install CCE 2.5
Re-install DVD2DVDR
I have WinXP and DVD2DVDR 1.3.4 found my CCE 2.5 -
well I am usind CCE 2.6, do you all think that is the problem?
Thanks alot,
dreadogg -
Yes, because the latest versions only support CCE version 2.50.01!
robw said:
The basic process depends critically on making TWO pulldown files as indicated in the reference above. Basically after DVD2DVD-R has completed its last step (CCE encoding) you must run two pulldown's.
run these two pulldowns
pulldown video_0xE0_NEW.M2V output.m2v -prog_frames p
pulldown video_0xE0_NEW.M2V output-drop.m2v -prog_frames p -drop_frame true
I am trying to backup Minority Report NTSC and DVD2DVDR says the video is interlaced and im not sure what puldown switches to use.
Thanks,
Tesla85 -
Originally Posted by gconrad2
1. Use must use BitRate Viewer on any one of the VTS movie files to get the correct settings in DVD2DVD-R. Do not run on the MENU file as you may get different settings from the movie.
In BitRate Viewer you need to reference the following fields:
Pic structure: Frame
Field topfirst: Yes
Quantscale: Nonlinear
Scan type: alternate
In DVD2DVD-R you need to look at the Encoder Options which are also found in the MPEG-2 video settings in CCE
Upper field first
Progressive frames
Linear quantizer scale
Zigzag scanning order
So what do I check in DVD2DVD-R to get the correct results from BitRate Viewer?
If Field topfirst: Yes -- check Upper field first
If Pic structure: Frame -- check Progressive frames
If Quantscale: Nonlinear - according to the Getting the Best out of CCE ALWAYS check Linear quantizer scale
If Scan type: alternate -- do NOT check Zigzag scanning order
2. You MUST check FORCE FILM which will execute PULLDOWN. Version 1.3.4 had a problem sometimes of not completing. It would do the CCE part but not exit to do the PULLDOWN. If this happens, exit CCE and DVD2DVD-R and you must do PULLDOWN (GUI) manually, no switches necessary.
3. Do Chapter Xtractor
4. Author with MAESTRO
5. Burn -
If you have problems with CCE not closing or process abording check this:
Make sure nothing is running.
Make sure your screensaver is OFF. Just turn your monitor off.
Check all the small icons on the right side of the taskbar, those are running tasks and can cause problems... MS messenger, ICQ, Kazaa, Scanner soft, Video soft, ... Close has many has you can.
Once you hit the GO button, dont even touch the mouse.
Make sure nothing will step on your keyboard while your away: Cats, dogs, childrens, ... -
joepic
I agree with your method. Only thing I wish to add is how to add subtitles. It changes the process only a little.
1. first get the subtitles with subrip.
2. when you run pulldown add one flag ... namely -drop_frame true
3. with drop_frame you also need to slightly change the format used by ChapterXtractor to hh:mms;ff (note the one semicolon)
4. Now Maestro will accept the four parts: video, audio, chapters and subtitles and all will be sync'd perfectly. -
@robw
Is this the same method you posted last time, because, this ones seems to have less steps?? (for the subtitle part in Maestro)
thanks
Frenetic -
Field topfirst: Yes
Upper field first
Progressive frames
Hi
I 'm not sure about the correct setting
What if : pic structor is : frame
dct type is : field
frame type : Interlaced
is it progresive or interlaced ?
please help
Regards
Klampe
Noob Encoding Package
By darkdream4 in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 14:44 -
Complete Authoring Package please?
By 1RealNewbie in forum Authoring (DVD)Replies: 3Last Post: 28th Sep 2009, 07:09 -
Best video editing package?
By donski in forum EditingReplies: 4Last Post: 3rd Jul 2009, 06:55 -
divx bundle package
By molinman in forum ComputerReplies: 1Last Post: 6th May 2008, 08:25 -
Picture Package Alternative
By cmcfalls in forum Capturing and VCRReplies: 0Last Post: 21st Oct 2007, 01:12
