Page 11 of 43
FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 301 to 330 of 1282
  1. I noticed a post here about the ifoedit NTSC bug where it cuts off time and puts chapters in wrong place.
    http://www.vcdhelp.com/forum/viewtopic.php?t=124896
    Back to the original post. I encoded a couple of movies with Rempeg and authored them with Ifoedit 95 and did encounter the time/remaining/chapter problem. I also encoded the four Alien movies using CCE and Ifoedit 95 to author them and they do not have the problem. All time and chapters points are reported correctly by my DVD player. Ifoedit captures cell times not chapters points?
    Is there anyway to add the parts needed from original ifo to the one ifoedit creates, because it should control how the frames of the movie should be played back.
  2. Anybody found a solution for subtitles getting out of sync ?
    1.- Subtitles extracted with DVD2DVDR
    2.- Video created with TMPGEnc using DVD2AVI.
    3.- Audio extracted with VobEdit.
    4.- VOBS Created with IfoEdit 0.95 DVD Author.
    The subtitles started perfectly sync with voices.
    but after some time, the subtitles started to appear 1 second before voices, then 2 seconds before, etc.
  3. @all the people who expierience CCE start problem
    Is the problem where CCE doesn't start after where it does the DvD2Avi part or after it creates the .vaf file and then starts to re-encode the .m2v file into the new .m2v.
    If it is for this process to re-encode how long do you leave it running for because i came across this and CCE sat there in between 5/10 minutes and then the status bar screen came up waited another 2 minutes and then started to encode the file.
    @all
    I have used Spruceup to author NTSC which have had pulldown run on them to correct the time loss. the only disadvantages to this is you have to manually set the chapters and DTS isn't supported.
    I don't rip subtitles so i don't know if you can do these in Spruce has well.
    Also i think it is only one .AC3 file per .m2v file but if someone knows if this is wrong then post to let us know.
    The movie i done was We Were Soldiers and i added my own menu to it but on TV the menu buttons were out of alignment and chapter selection were out of alignment.
    I don't claim this to be the best way but if you can live with the limitations and don't have the other authoring programs this can fill the void till either ifoedit bug is fixed or something better comes along.
    Nov 2002
    Mechelen-Belgium-Europe
    Is the problem where CCE doesn't start after where it does the DvD2Avi part or after it creates the .vaf file and then starts to re-encode the .m2v file into the new .m2v..
    CCE does start up in versions 1.3.3, 1.3.3a & 1.3.3b but it never loads the VAF-file!
    In 1.3.3 I left DVD2DVD-R running for more than 2 hours as it took +90% of my CPU in windows taskmanager, but nothing happened!
    -BK-
  5. Quick question... in the absense of a working IFOedit I'm using maestro in the short term..
    So I use DVD2DVDr to rip and de-mux the video.
    Now if the video need not be re-encoded, so I'm basicaly just dumping the demux video/audio into maestro, do I need to run pulldown on it? or will it already be in there from the source or will maestro add it in?
    thanks,
  6. @BK
    CCE comes up straight away for me, it is only the encoding part that takes its time coming up.
    If it helps in anyway i am using
    Win Xp Pro, P4 1.9ghz, 512mb, Both H/D's are Ntfs.
    @dc91gt
    Being as Maestro and Spruceup are done by same company i would say yes you will need to run pulldown.
    I should think even though movie hasn't been re-encoded it still has in a way by demuxing into a movie and sound file. and would say you would need to Run Pulldown.
    I tried in Spruceup and received a frames error and set prefs to NTSC. But .M2V i ran thru Pulldown went in fine.
    Easiest way to try is to see if you can compile the disc with .M2V which hasn't had Pulldown run on it and see if it lets you carry on because Spruceup won't let you get to this stage.
  7. Originally Posted by robw
    http://users.pandora.be/DVD2DVD-R/
    now press the top tab, 2nd from the right that is labelled DVD5/9 2 DVDR
    Now the bad news: The guide is written in Dutch. Still, I think you can puzzle through the writing (I could) and get a lot of information.
    This guide looks excellent any chance of a translation for us lazy Brits who cannot be bothered to learn anyone elses language.
    Nov 2002
    As there is a lot of interest in my site, I think I will put an english version online too
    So keep asking guys
    -BK-
  9. @dc91gt
    Looks like you don't need to.. i just stuck the demuxed audio/video that dvd2dvdr generated into maestro and it didn't complain and the playback is fine (source was 23fps). I did forget to adjust the aspect ratio in masestro tho... so the aspect ratio is off.. crap. ahah
    btw... to anyone following the FF/Chap advance problem I was having with dvd2dvd-r and then IFOedit authoring ... well using maestro and chapter extractor -- problem has gone away.. so like I suspected it.. it was ifoedits problem.
    This is good news for me at least haha.
    thanks mosh.
    -d
  10. I want to make a backup of the movie 54. The main movie(4137mb) actually fit on a singel layer and no encoding required.
    The DVD including extras is 4535 mb. I therefore want to reserv some space for extras, the problem is that i can't change
    any options in the MPEG Encoder section. Can some one help me with this problem?
  11. @Espen
    Even though the encoder options are greyed out you can still change the settings.
  12. Can anyone answer me on this???
    I may have a stupid question: Is topfield in bitrateviewer the same thing as upper field first in dvd2dvd-r? I am asking because if bitrateviewer says my dvd is interlaced and it says topfield=true I would think I need to check the upper field first optin in dvd2dvd-r (even though they say not to check it with interlaced video in the help file that comes with dvd2dvd-r)
    thanks, any clarification on this will be greatly appreciated.
    Frenetic
  13. @Frenetic
    Yes the top field = upper field
  14. Originally Posted by dc91gt
    Here are some great GUIDES for DVD Maestro:
    http://digital-forums.com/dvd2dvdr/intro.htm
    This is a list of some of the software that is used in this tutorial:
    ChapterXtractor v0.961
    Spruce DVDMaestro v2.9.2915a
    Follow the example on using ChapterXtractor and DVD Maestro to retain your chapters.
    Here are a couple more examples of using DVD Maestro
    http://www.fukrulez.com/modules.php?name=Content&pa=showpage&pid=11
    http://www.doom9.org/index.html?/mpg/maestro.htm
  15. hey all,
    i have version dvd2dvdr 1.3.2 installed. i have CCE 2.64.01.10 installed which should be supported, but it cant find it and gives an error.
    also the box in the MPEG encoder tab is greyed out....so i cant choose it either.
    anybody an idea ??
  16. I know I am way behind, but when I try to install the program I get a little window saying(Install ASPI driver first). I have an Sony DRU 500a in my machine and I only get when I click on the CD icon. Can some please help me.
  17. when dvd2dvd-r finishes ripping the dvd it looks for dvd2avi when it finds it it says starting dvd2avi but then i get an error.
    all im left with in the output folder is an m2v file which is 4.9 gigs and a ac3 file which is 350meg
    anyone any ideas on whats went wrong?
  18. Member
    Nov 2002
    Holland
    Hi,
    When starting the rip/decryp. process the log says
    19:51:43 checking Filesystem...OK
    19:51:43 checking free Diskspace for ripping...OK
    19:51:43 checking free Diskspace for encoding...OK
    19:51:43 checking Outputfolder...OK
    19:51:43 checking Outputfile...OK
    19:51:43 updating PTS-Values...
    I think he's hanging in the updating progress....or is this something
    that can take more then 30 minutes ?
    Someone ????
    Problem solved.......
  19. Originally Posted by jhhack
    i heard this program will only do PAL? is that true?
    No, I've just ripped NTSC from Disc. So, that works! I needed to adjust the setting though. It asked something about keys. I checked "Secure Authentication" and "Keysearch at every Cell-ID" in the "Settings" tab. After this, it worked just fine. After restart the "Keysearch at every Cell-ID" is unchecked again, beware.
  20. Originally Posted by Merciless
    you need to load ASPI drivers... go to www.doom.org and download "forceapsi 1.7". Run it and reboot.
    -d
  21. Originally Posted by joepic
    Here is another example of using DVD Maestro
    Thanks for the link.
    I actually figured it out pretty quickly last night, it's quite a straight forward program. So much nicer then IfoEdit.
    -d
  22. Member
    Dec 2002
    ASShole of the World
    I am very happy with your proggy, havent tried the 1.3.2, and there still are a few bugs but for a newbie like me its great.....
    I am running a duron, version 1.3.2
    Ifo edit.
    And Nero to Burn...UDF/ISO 1.02
    Seems to work great, have encoded movies no problem... Work on everything but my ps2, and a Zenith I have tried....
    Anyone out there know if you can get a IFOEDIT Authored DVD to play on a PS2 with a mod chip in it... .
    Thanks Ya All.....Mighty. :P
  23. Anyone ripped the series Band Of Brothers yet? Are they DVD9 or 5 or how much work would it be?
    Hide
  24. Hi all
    I have big problems burning dvd movies
    i have authored the dvd with ifoedit 0.95 and burned it
    with prassi primodvd , it works fine in my pioneer 454,
    but when i try in pioneer 717 , it won't work
    i tried other dvd-r in the 717 they work fine , but that is
    movies i haven't ripped
    i have also tried other burning programs , Instant dvd and gear pro
    in gear pro i got an error when draging files into the VIDEO_TS folder
    it came out with at Start adresse error ???
    i have also double checked that i have used "Get vts sectors" in ifoedit
    I looked around in the forum , and i can see some others using nero , but it seems that it doesn't work on all machines either
    something i dont have tested is , to make a image in imagetools99
    the way i have done it : i have created a folder called AUDIO_TS & VIDEO_TS , and dropped the files in the VIDEO_TS folder , is there
    do imagetools 99 do anything different ???
    Please help me , its a very big problem for me
    Regards
    Klampe
  25. @Klampe
    I use Nero for all my dvd burning and have had no problems playing them on the few standalones that i have access too.
    I had no success with Prassi for movies but then at time i used cheap dvd-r's that sometimes had probs reading in my DvD-rom (When i backed up pc files) and i had to use burner to read.
    I have authored with both ifoedit and Spruceup and these still work fine.
    I think it is hit and miss has to what standalones they work on because i done Spiderman and it played on 4 out of 5 standalones (bearing in mind these are low end dvd players). If they didn't work on any standalones then i would be looking at possibly doing something wrong or changing software but what can you do because the end product proves to be working 90%.
    So it must be either the media that that particular standalone don't like or the standalone itself reading dvd-r's created by your burner.
    It would also help to tell us what burner you are using incase someone else has expierienced same problems and have now been able to fix.
    Have you burned and tried testing another brand of DvD-r.
    Give Nero a try and see if this improves things all round or if DvD-r's created using nero work on this player.
    But other than this by them working in one player says you are doing things right have you tried these discs on other standalones you have access too, to see what happens.
  26. I have been able to rename the vobs to the original numbers and copy them over to the original folder.
    That way you get a full copy of the dvd, including all the menu's and extra's.
    The only thing I haven't gotten to work is the chapters, when you do a scene selection, these seem to take you to the wrong place, also the number of chapters is not correct. It seems like the cells are not correct.
    I use ifoedit to do the authoring and run the get vts sectors and I run the get vts sectors again in the original folder as well once the files are copied over.
    Anyone know what might be the problem ?
  27. Member
    Dec 2002
    Pennsylvania, USA
    I'm a newbie to burning DVDs and have been trying to use DVD2DVDR. I've followed the instructions and the movies look great however I have a constant problem with the sound track lagging behind the video. The track almost seems to get further behind as the movie goes on.
    I know I must be doing something wrong, but I can't seem to put my finger on exactly what is the problem. I will notice about a minute after I know where a certain dialog should be that it will play but by then the movie is, as I said, a minute further along.
    Can someone give me some help? I'm using version 1.3.1 of the program. Thanks
  28. @redwingnut
    Have you tested the movie by selecting dvdplay in ifoedit after you have authored the .M2V and AC3 files to see if it happens here.
    are you getting any errors in the log of dvd2dvdr.
    after dvd2dvdr rips the vobs it checks the audio file for delays and possible probs..is this reporting any error or showing that sound file has bad sections.
    is it one, all or certain movies that do this.
    if you feel you are doing something wrong write down the steps you are doing so if a step is being missed that can be sorted.
    it would also help if you tell us what software you are using to author and burn the dvd with.
    also what you are using to play these discs on.
  29. Member
    Dec 2002
    Pennsylvania, USA
    Thanks for the quick reply mosh.
    No, I don't believe I have actually used the DVDPlay to test the files. I'm using CCE 2.5 to do the encoding, and I've burned the image with Imgtools 0.99.3 .
    I've tried other methods and don't get the delay but DVD2DVDR is so much less hands on and the steps seem so easy that I'd like to use this program.
  30. Member
    Dec 2002
    Pennsylvania, USA
    sorry, mosh. forgot to respond about what dvd players I'm using. I have a APEX AD1200 and a Samsung DVD-V2000. Both seem to play both the DVD-R and DVD-RWs that I'm burning.
    The interesting thing is though when I try to use PowerDVD it will say that the disc is in an unsupported format. If I then go in and double click the main movie file it'll start up and play fine.
    Thanks again for the help
