  1. Hey
    I wrote to you before, because i had 3 vcd's that wenn they were burned they were mirro loke and upside down ( when i play them on my dvd player) when i just play them on the computer there is no problem, they are fine !!! i have burned before without any problems. !! Then i did the worst i made af format C: so i started all over again, now i just got bend it like beckham - and pochahontas 2 THEY DO THE SAME what the hell is this ????????????
    P L E A S E H E L P
  2. I had the same problem.
    I installed the Nimo Codec pack and made sure I selected to install the Bicubic Resizer Filter. This fixed it.
    Let me know if it worked for you as well!
  3. I got same problem with Nero burning the MPEGS upside down.
    Also when I drag MP3s into Nero add files window the first selection becomes the last automatically so when I doing an album I have to start with last track working upwards.
    What is wrong?
