Hi all,
I have a Leadtek WinFast 2000 XP and do capturing with
the Leadtek software and Ulead VideoStudio 6.
After a few capture runs I have always the following problem:
The screen freezes after 40 to 60 seconds during the capture
process. After a new installation of DirectX and the drivers, the
problem is solved for the next few capturings. When it comes to
a screen freeze, it will reoccur at every capture process until I
reinstall the above mentioned software. It looks like some drivers
have been damaged ?
I had a few times success in only reinstalling the DirectX 8.1b drivers,
I tried also older versions of DirectX, but there was the same behaviour.
After a few capturings I have always to reinstall the software.
Has anybody an idea or experienced the same ?
My system:
Athlon C 1GHz, VIA chipset, 256 MB RAM
Win98SE, PCI latency timer patch (George Breeze), DirectX 8.1b
I have been having the same problem for ages. System freezes at random times during capturing. If i did a fresh install of winxp - it would capture fine for a few times then the lockups would start again. I have tried everything - via 4in1 drivers, pci latency drivers, other capture cards. This is driving me mad. The lock ups only occur if video and audio is captured together. capture video fine for hours on its own.
Is this a problem with via chipsets or winxp maybe. Please, if someone has had the same problems and managed to fix it - please let me know.
p4 2.20g - ecs p4svxd2 motherboard
512 meg ram - 120 7200rpm hd
i have used avertv and wintv capture cards
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 19:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
