I have been using CCE 2.64 to re-encode movies > 4.3 g. I have been using CCE in combination with DVD2SVCD which works great. The problem I have been coming up with is that I normally do a 3-pass VBR. When the encoding is complete, I usually have a combined audio and video file of 3.8-4.0 gigs. I would rather it be closer to 4.3 gigs (at least 4.2 gigs) so that I can maximize the video quality. I have increased the "CD size" option on the bitrate tab to 4350, but the re-encoded size didn't change. Is there a way to tweak it so that I can get much closer without going over? I know in other encoders I can use a bitrate calculator and can get VERY close, but of course it takes MUCH longer to encode. What would you guys suggest? BTW, I have been using the default bitrate options of "max" 8500, "min." 300, "max ave." 4500.
Thanks.
Results 1 to 1 of 1
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 03:41 -
Embedded attached picture (covert art) max size
By Brazil in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2009, 06:56 -
Max Hard Disc Size on PS3?
By SCDVD in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2008, 04:11 -
Controlling CCE's output file size.
By astrocity20 in forum DVD RippingReplies: 24Last Post: 13th Dec 2007, 22:32
