sorry for the question if it been asked before, but i`ve recently downloaded a film from kazaa which i want to convert to vcd. i`ve tried using TMPGEnc, but had no luck.
i clicked on browse from the video source and loaded the file but got this message - "filename" can not open, or unsupported. the properties of the file is as follows:
Audio format: MPEG Layer-3,40 kBit/s, 24,000 Hz, Stereo
Video format: 352 x 288, 54466 Frames, 20.000 Frames/Sec, 55 KB/Sec, Unknown Format.
can anyone shed any light onto this (preferably without flaming).
many thanks
a complete novice
I may be Welsh, but I don`t sh*g sheep.......unless they are related.
Is the source in divix or mpeg.
If it is Divix it looks like your dont have codec installed
Download Codec from:
http://www.ksdivx.cjb.net/
or
tools section on this site. -
i have this problem too. to bypass it, i have to encode the avi into another avi using virtualdub with direct stream copy for video and full processing for audio to a pcm 44k output. then i can encode to mpg. you'll get better sound this way anyway. tmpegenc decodes off-standard sound poorly.
chas
where did I go wrong? Mkv to Avi.
By zorbathegeek in forum Video ConversionReplies: 2Last Post: 1st Jun 2010, 18:01 -
What's Wrong With This AVI?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 29th Jan 2010, 12:17 -
What is wrong with AVI file?
By vertical in forum Newbie / General discussionsReplies: 8Last Post: 2nd Feb 2009, 00:51 -
AR wrong when importing this AVI
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 13:19 -
Super8 to .AVI conversion, what went wrong
By rjonkers in forum RestorationReplies: 13Last Post: 18th Feb 2008, 13:43
