Hi,
I'm new to this so please bear with me. I've successfully managed to rip several DVDs and rempeg them, burning them with Nero. The only problem I have is with the Aspect ratio. Non Ripped DVDs play in the Letterbox format, whereas the Ripped ones play fullscreen. Am I missing the sides of the picture? or does it stretch the picture upwards? Have I not set all the flags in IFOEDIT correctly? I'm following one of the easiest guides and trying to just burn without any menus etc.
Any help would be greatly appreciated...
Andy
Do you use tmpgenc at any stage?
If you do, there's a setting in a drop-down menu inadvanced settings (after you choose 16x9, NTSC), which says something like 'Center Screen, Keep Aspect Ratio'.
That way, you get letterbox output.My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
I'm actually using Rempeg. If I play it on my PC then it appears to come out correctly, but not on my Panasonic DVD player (can't remember the model but it ends in 10X). Does it not recode in the same aspect ratio?
It TMPGEnc any better than Rempeg? What other benefits would it give me?
Regards
Andy -
Before going mad with the encoder, try to change the screen aspect ratio on your player .
On mine choosing among 4:3 letterbox, 4:3 pan&scan or 16:9 usually can adjust to the right view.
Give it a try
Riccardom -
My player has only 2 settings: 4:3 and 16:9. It's set to 16:9 and the original disk works fine, but the ripped disk does not. I'm sure it's an aspect ratio setting somewhere in the Disc, but have no idea where to find it.
Many thanks for the reply
Andy -
I'm not familiar with rempeg, but I have to assume it has similar options for ratio settings somewhere in there.
The fact that your player is set to 19x9 but the DVD still playes 4x3, would indicate that this was done at the encoding level. But I could be wrong
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Sony 8x DVD burner
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 02:53 -
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 19:44 -
Aspect Ratio
By thesuperhemanshow in forum EditingReplies: 0Last Post: 5th Jan 2009, 16:36 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 01:41 -
Aspect Ratio
By kolias in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 08:28
