Help please, does anyone know if the pacific phc 200 home cinema system (from asda) can play dvd r. I've tried some but the disc just spins and I get the message loading. I had this problem with mp3's and vcd's as well, but I found if I use discs that are blue i.e. sirius or the old 24 speed datasafe discs they work. Also the 9817 code for making it multiregional works too. I suspect it will play dvd r as well but I probably need to find the right disks, the ones I tried were purple, i don't know the brand cos they were borrowed. So can anyone recommend a dvd r disk that may work. Also does anyone know where I can get any information on who makes the pacific models for asda.
Thanks in advance.
