I have a movie as an avi file that I want to make into a vcd.
When played in windows media player, it opens quite big, about half the screen.
But after using TMPGenc it is about half the size of the avi, so when it is opened to fullscreen it is very pixalated.
What settings do I need to use in tmpenc? I tried 1:1VGA, 4:3 and 16:9 (the movie is 16:9 widescreen), I also use Fullscreen (keep aspect ratio 2) aswell.
Right-clicking on the .avi movie, and choosing properties, it says the dimensions are 640 times 272 pixels.
TMPGenc is making a mpeg of dimensions : 352 times 240
Why the difference?
Thanks for any help
VCD standard IS 352*240 *288 for PAL) so TmpGenc is doing the right thing. If you want to make it bigger, try SVCD or DVD standards. I suggest you take a look at the WHATIS section to your left to help in your decisions.
Issues with Dimensions on Export
By jherzog in forum MacReplies: 3Last Post: 19th Jul 2010, 16:29 -
What's the Dimensions for a Title Screen?
By blaqlion22 in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2009, 01:13 -
x264 - new pass with different dimensions, is it OK?
By kurbads in forum Video ConversionReplies: 16Last Post: 5th Sep 2009, 07:57 -
Tool for Viewing video/avi info (duration, dimensions)
By deco81 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2009, 21:10 -
batch WMV to AVI that will maintain video bitrate and frame dimensions
By chief1972 in forum Video ConversionReplies: 2Last Post: 27th Dec 2008, 14:17
