My apex 703 refused to play any kind of cds and DVDs after using it for several months. It just keep loading the cd forever. Does anyone know what is the problem and how can I fix it?
1. Clean the disc (REALLY GOOD).
2. Clean the laser (Buy a CD-ROM laser cleaning kit, all it is is a special disc with brushes on the bottom)
3. Adjust the laser (I don't know how)
AP Enterprises Ltd. -
I have had a similar problem when I place the unit with regions off. When I put the unit in the region I am watching the problem goes away. Although my problem was not as extreme, after two or three trys it would finally work. I also noticed that the problem was less noticable if the disc was in try three??? Good luck
Capt. Diode
Dead Transformer Take Down
By budwzr in forum Off topicReplies: 20Last Post: 14th Mar 2012, 14:01 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 08:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
