  1. Hi there
    Ive recently got a Pixelview Play TV pro TV tuner card
    PV-BT878P+ w/FM chipset
    and am wanting to capture an NTSC vhs tape
    I have two problems..
    1.) I am able to connect my vhs to the composite in of my card and get video from the VCR but the audio cord from the VHS to the audio in at the back of my tv card wont fit at the card end so I cant get sound, what kind of cord do I need to get audio??
    2.) When trying to capture NTSC vhs in Virtual Dub, when selecting
    Video --> Source --> NTSC-M the picture is black and white!!
    How can I fix this so I get colour?
    Both my VCR and Capture card are supposed to support NTSC
    PAL vhs video is fine tho
    THanks for any help with this
    Oct 2002
    Manila, Philippines
    What type of connector is in your card? Is it mini (baby) plug? If so you can get a RCA to mini plug converter in any electronic store. Get the stereo type
  3. Yes its an rca connection i think thanks for the advice! :P
    Oct 2002
    Huntsville, Ontario, Cana
    is there another NTSC setting in your capture software. I remember with my old ASUS card, one setting only did B&W while the other did what the source was.
    Will
  5. Theres two software settings one is NTSC-M and NTSC-JAPAN but both are black and white.
    I live in a PAL (europe) area and the VCR i have is multiformat (supposed to play NTSC and PAL tapes) could it be the VCR itself?
    Ive heard that these VCR's dont give true a NTSC signal is this right?
    Jul 2002
    You've answered your own question!!!
    unfortunate, but true
    "The software said Win XP or better, so I Installed Linux"
