this is happening quite alot, but tonight it hit me the hardest, i capped WWE Survivor Series PPV of course i had the capture drives enabled at 2GB and multi seg cap on,capped PPV , 2 drops, goto open up VirtualDub to deinterlace first capture (main one), it goes fine, now i try to deinterlace the first split(file 2) it says:
"Error Decompressing Video Frame:0
A Codec-Specific error accured
(error code 1)"
its the same with all multi segs, so badicly the capture is f$%&ed
if i try to play the first avi in PowerDVD it works fine, but the rest, peh windvd get a error
Hmm if you capped to avi then you can try divfix.
http://www.divx-digest.com/software/divfix.html
But do an copy of the file before if divfix crew it up.
Avi showing wrong length. Encoded with virtualdub
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 3rd Nov 2011, 12:06 -
VirtualDub cut .avi at "wrong" place!
By larsli in forum Video ConversionReplies: 10Last Post: 17th Sep 2010, 08:25 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Virtualdub - What did I do wrong?
By tigerb in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2008, 11:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
![Send a message via AIM to [R][V][D]](images/misc/im_aim.gif)
