I have an avi file that when I play on the computer is about 84 minutes in length. However, when I try to use TMPGEnc it gives the file length of more than tripple the length (254 min). I am going to try to use this program to "squeeze" it on an 80 min CD. I think I can tweak some of the values if I can get it to recognize it as an 84 min file rather than a 254 min file.
Thanks for any help.
Open the avi file in virtualdub. If it gives a warning about VBR audio, that is your problem. Try searching the forum for the solution, it has been discussed frequently.
Can no longer scan just one file in AVG
By V Bot in forum ComputerReplies: 7Last Post: 29th Mar 2010, 10:22 -
feedback: while uploading file, my logon times out, and lose url link.
By vhelp in forum FeedbackReplies: 1Last Post: 1st Mar 2010, 07:53 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28 -
How to automatically split a .dv file at certain times
By conrad787 in forum MacReplies: 3Last Post: 21st Oct 2007, 09:41 -
Burn Times 3x longer after I installed AutoGK
By Gunewbie in forum ComputerReplies: 6Last Post: 19th Jul 2007, 22:45
