when i opened my .avi file to cut, virtual dub gave me this message:
Couldn't locate decompressor for format 'DX50' (unknown)
VirtualDub required a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
i have a funny feeling this means i don't have the right codec, but this video played fine in windows media player and the divx playa
You should also mention codecs you yourself loaded. Mainly, I am looking for the Nimo Codec you loaded.
Hello. -
Don't know if this helps but...
DX50 is DivX MPEG-4 version 5 http://www.divxmovies.com/codec/
See www.fourcc.org for information on fourcc id's.
Which version of directx do you have, you need version 5 by the sound of it. -
ok, all the codecs i have are the nimmo pack v5.0, and the latest divx. along with any codecs that windows media player updates all on it's own. as i mentioned before, this movie can play fine on windows media player and the divx playa, so it's gotta be something wrong with one of the codecs i have. it sounds like that codec is incomplete or needs to have a certain component that virtual dub needs.
i downloaded some avi's recently and i tried to join them and got the same message that i needed a vfm codec....... can someone shed some light on this subject ? i would like to join all the clips.Originally Posted by xX_Toilet_Duck_Xx
How do I get the exact file size I want with Virtual Dub ?
By Simmons in forum Video ConversionReplies: 3Last Post: 21st Jul 2011, 01:32 -
Virtual Dub delogo output file help
By Rogert in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2011, 12:25 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58 -
how to batch file in virtual dub?
By warlock110 in forum Video ConversionReplies: 2Last Post: 17th May 2007, 00:56
