I am very interested in purchasing a DVD burner. However, I was wondering why DVD2SVCD can't be used for the entire encoding. I would like to do many movies with very little time involved. I don't care about any menu's. I just want to be able to do this in as little steps as possible. Can't I just use DVD2SVCD, adjust the settings like CD length, min., max., resize to get the DVD Mpeg. I'm assuming DVD's encoded material can't use cue/bin files, because every DVD to DVD-R guide I have read says to disable the CD image. However, can't I just take the created MPEGs and use an authoring tool like VCD easy to create fixed chapters? (I'm missing something here, aren't I) Anyway, is this possible? I would be even willing to sacrafice dolby 5.1 (sorry audiophiles) at the sake of simplicity if that is the factor preventing this to be done in one step like SVCD creation. Any input would be helpful.
Actually I already looked at the guide. I'm not familiar with Ifoedit or DVDmeastro. (I guess I'll have to) I guess my question revolves around, "Why can't the whole thing be done on DVD2SVCD?" In other words why can't the settings be adjusted for DVD and create the images, then just burn them?
Thanks -
Because DVD2SVCD cannot create DVD images since its designed for SVCDs. Their structure is totally different.
If you give the guide a chance you'll find that DVD Maestro is super easy after following it through a few times.... -
That's what I thought. I just needed someone to tell me
. Thanks
I'll definitely give it a try (when I get the burner)
Another VHS capture to DVD post, but cost is not really a factor
By Valnar in forum Capturing and VCRReplies: 6Last Post: 25th Dec 2008, 15:16 -
What is a scale factor?
By rocky12 in forum Newbie / General discussionsReplies: 47Last Post: 22nd Jul 2008, 14:34 -
Laptop Upgrade: "Form Factor" for DVD/CD Recorders?
By CobraPilot in forum ComputerReplies: 4Last Post: 11th Nov 2007, 02:21 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
File Association hassle factor
By ahhaa in forum ComputerReplies: 2Last Post: 26th Aug 2007, 22:25
