I seem to always get a error like "Illegal Floating Decimal Point Calculation Order" and was wondering how to fix it? does it have something to do with the file or the encoder settings or what? i am using the newest TMPGENC Plus.
Results 1 to 9 of 9
Did you enable cache vbr in the enviramental tab? If you did turn it off.
Nope didnt help still getting error. can anyone else help me?
if you are using tmpeg for the encoding and you
seem to have a "floating point problem"
do the following:
in tmpeg
select "options"
select "enviromental settings"
select "vfapi plug-in"
you will see a list of plug-ins
right click on a plug-in named "directshow multimedia file reader"
you will see that it has a priority of "-1"
you need to increase that to "1"
by selecting "higher priority" until it becomes the first in the list.HELL AINT A BAD PLACE TO BE -
Also, it might help in TMPGEnc to check "Use floating point DCT" under the Quantize matrix tab in Settings.
Hope That Helps!!! -
Also Tried that didnt help any also :\
i have gave up and just used CQ thanks for all the help. -
Try grabbing a XVCD template from www.kvcd.net, run that through TMPGEnc and see if it does the same thing, also try a different movie to encode, might be a problem there.
The key is dont give up stay at it, Ive spent the past 4 months playing with this stuff and I still dont produce stuff Im 100% happy with, so read read read, and play play play, youll get thereThe Hellsing family will purify this world...
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 21:11 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 05:46 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
