Ok, I want to capture mostly from my VCR (standard RCA inputs) to DVD-R at DVD quality resolution. Here's a couple I'm looking at, but if you know of any others that would suit my purpose please let me know.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?sku=A03-7032%20P
seems like a good deal, but these others claim to capture 720x480 instead of 704x480.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?sku=D450-1078
This one seems nice, but the 150 model claims that it's USB 2.0 support gives 25% better quality.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?sku=D450-1074
the DVC 150 model. Does the USB 2.0 really matter?
It CAN matter, but not always. USB 1.1 limits you to 5Mb/s bitrate, and that's NOT VBR. This is half of what DVD is capable of, so in REALLY hard to capture scenes, there may be slight quality issues. Having said that, my ADS IDVD looks very good to me. The 704 res isn't a big issue - it's an earlier spec, but DVD compliant, and it's only a 2% reduction in res.
The BIG issue is, these critters don't cap audio - they use your PC soundcard. That means you need a good soundcard for good sound. Also, this method often results in audio/video sync problems, particularly if you're going to edit the captured video. I personally haven't had these problems, but many have. Plus, ADS & Dazzle haven't had great customer service on these units.
If you want hardware capture on your PC, do yourself a favor - get a PCI card based on the iTVC15 card - Hauppauge PVR250 or similar. That's the best cheap stuff going. If you *NEED* USB (I wanted to do this on my laptop, or I'd have the PCI card), I'd try the ADS, but consider all the warnings. -
Well, I didn't say I don't have USB 2.0, it's just that it's more expensive.
I'm leaning toward the DVC 150... I found it for $170 elsewhere ($30 less than Tigerdirect). http://www.pcnation.com/asp/details.asp?item=449033&technote=Y
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 10:17 -
Help Deciding on VCR
By generallee in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2011, 19:11 -
I'm having a problem deciding what Capture Card to buy
By Mufc in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 09:10 -
Media to TV, Deciding Best Way, Advice Please
By ndhl56 in forum Media Center PC / MediaCentersReplies: 7Last Post: 27th May 2009, 06:19 -
Help deciding what to replace my old TV with
By LT9000 in forum DVB / IPTVReplies: 8Last Post: 1st Sep 2007, 01:21
