I have two really old home videos of a band that are not on DVD, the VCD versions look like sh!+. I'm going to author my own. They both will fit on one DVD because they total only about 115 minutes. I want a menu that shows up when you put the dvd in to have two choices. One's a live concert and the other in like a video scrapbook. The user will select one choice and depending which one they pick will lead them to another menu with chapters and a play all menu. Kind of like the DVD movies where you can pick between widescreen and fullscreen versions o the movie like Monsters Inc, The New Guy, and What's The Worst That Could Happen. Except there will be two different movies instead of a widescreen and fullscreen version.
Ulead DVD workshop can do what you want, you can have moving menu's also.
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 09:14 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 09:23 -
Exact copy of a DVD to a container playable in itunes
By jamsponge in forum DVD RippingReplies: 5Last Post: 20th Jan 2009, 10:19 -
How to make exact screencaps easily from DVD?
By zee944 in forum Software PlayingReplies: 30Last Post: 8th Aug 2008, 03:06 -
how do i convert the exact same AVI file to DVD on avidemux?
By whodini in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2008, 19:14
