I have downloaded an avi file but divx wont play it and it wont convert to mpeg, i also downloaded a sub file whatever that is. Does anyone recognise my problem.
Post your question in 1 forum only.
You may not have the correct codec installed. Try installing the nimo lite codec pack -
Its also possible that it isnt a DivX not all AVI's are DivX.
The Hellsing family will purify this world... -
Open the file with virtual dubb and check the file info to see what codec was used on the avi.
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 15:22 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 12:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
