I've just Burnt my first VCD but the picture keeps freezing I also get coloured squares on my screen. I used a already made VCD and converted the Dat file to a Mpeg and then burnt the VCD using Adaptec software using the guide off this web site and then playing it on my Philips 701 DVD player. I dont know why the picture freezes any one got any ideas other wise I might just quit before I have started LOL![]()
Cheers
what speed u burning at? - never go any faster than 4x. also, most important- dont touch your puter during the encode process
Never say never, I burn all my VCD's at 24 speed on 32 speed intenso media with no problems. Just ordered a 52 speed liteon burner and 48 speed intenso media, will see how fast I can go.Originally Posted by davemcg37
@maduncledai,
The first rule of thumb when posting a question like that in this forum is to try to include as many details as you can in your post concerning your conversion process. Things such as frame rate and codec of the original file, what tools you used such as did you use TMPGEnc or another MPEG encoder and what template you selected, did you load up the file directly or frameserve it thru another application such as DVD2AVI, VirtualDub, avisynth, ect. Also what burning software did you use? Did you use any other program to author the VCD such as VCDEasy? The more you tell us the easier it is to answer your question.Warning! I'm baaaaaaaaack -
Sorry to dazzel you with all the techno babble, but the point I was trying to make was to try and provide as much information as you can. Anywhere along your conversion process could have intoduced the problem your seeing. Try listing the steps you took:Originally Posted by maduncledai
Information on the source avi file such as the audio/video codecs.
The tool you used to convert to MPEG for example: TMPGEnc, Cinema Craft Encoder, Ligos. ect.
The burning software for example: Roxio Easy CD Creator, Nero Burning Rom, ect.
Another thing, unless you have an extremely old CD burner or using cheap media the burning speed isn't going to play much into this since I burn at the max rate the media supports and it's never been an issue for me.Warning! I'm baaaaaaaaack
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 15:52 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 22:15 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
Using ConvertXtoDVD Trial Version and freezing picture
By DJL82 in forum Video ConversionReplies: 6Last Post: 8th Jan 2008, 18:55 -
TEVION 8000 / 8001 HDMI DVD PLAYER problems with picture freezing....
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 10:56
