Hi folks,
I'm hoping someone can help me out with my question...
Will a Hi8 recorded tape play in a non-Hi8 player?
I had some serious trouble finding anything out about 8mm equipment on the net. Any help you could provide would be greatly appreciated.
Thanks,
Dan Bruner
bruner@shol.com
Guest
Thats aloaded question, do you mean what you have recorded as HI-8mm play on another non-HI8mm machine, thats a yes or no question.
Some of sony's Home 8mm players, I have one that will play HI-8mm or 8mm and its just a 8mm deck, their sort of like Quasi-VHS. Sony put chips in some machines to allow HI-8 playback in their non HI-8 machines.
But if you mean can you use a HI-8mm blank tape in a 8mm, no problem it will work fine, I have even taken a 8mm tape punched a hole in the right place so it would record HI-8mm.
I do not know of any 8mm camcorder than will play a recorded HI-8mm tape correctly, it was just the home decks only. -
Nah...
It's like playing a s-vhs on a regular vhs player... nothing but static but you can copy from the camers to regular using the V/A out.
8mm black streaks
By mark23 in forum RestorationReplies: 15Last Post: 13th Feb 2012, 10:10 -
editing old 8mm movies
By rosmari in forum EditingReplies: 15Last Post: 2nd Apr 2010, 12:14 -
Question AVI Captured with DVSplit passing 8mm camcorder thru Canon HV30
By vtkahns in forum Video ConversionReplies: 0Last Post: 27th Feb 2010, 16:46 -
8mm camera
By dyanarosejill in forum Portable VideoReplies: 2Last Post: 10th Mar 2008, 20:09 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 22:28
