I have couple movie files which are more than 700 MB.
Is there any good software will help me to cut the movie into two pieces and still remain the .AVI file format? So, I can go ahead and burn to the CD.
I tried a very simple software call File Cutter. Howver after cutting the file, it stored the files with extension as 000 and 001 instead of original AVI format...
Any suggestions???![]()
Please help me out here
Thank you
If it's an AVI, you can use VirtualDub to cut it - see the howtos under EDIT.
But remember - If you're going to do a VCD, the size of the original AVI doesn't matter a bit. It's the length (in time) of the movie that determines if it will fit on a CD as VCD.
/Mats -
If you take a look to the left, you'll see a section with the heading OTHER. About 2/3 down this section, there's a heading Tools. Contrary to common belief, this doesn't list various hardware stores, but comments and links to software related to the manipulation of digitalized moving images.Where can I find this software?
/Mats
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 19:32 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28 -
Best way to split an MPEG file is to ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2009, 21:31 -
how to split a FLAC file?
By tomchook in forum AudioReplies: 4Last Post: 9th Mar 2008, 23:04 -
split one file avi in two
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 15:13
