I am trying to change an .avi XVID codec
since it is such a problem to encode with
TMPGE. I use VirtualDub and select
Video---> Full Processing Mode
Video Compression---->DIVx Low Motion
The above was in KingJohn’s guide.
The problem is with the audio. The file information is:
Video Stream 640x272 XVID MPEG-4 Codec
Audio Stream 48000 MHZ sampling rate
Channels 2(stereo)
Sample Precision 0–bit
The problem is that I get the following message when
attempting to change Audio Compression (using Full Processing Mode):
The requested audio compression is not compatible with the input
format. Check that the sampling rate and channel count of the input
match those of the requested format.
Any suggestions?
When in doubt: Dump problem format to Uncompressed WAV.
With V-Dub, go "Save Wav". Open that "Wav" in Winamp (older versions) and it should handle it (yours sounds like .mp3). Use the "Disk Writer" plugin...
Particularly on DivX files, Virtualdub and other programs won't treat .mp3 audio as .mp3, it will treat it as "MPEG Layer-3 audio" with wav formatting to it. It's nuts, but you have to sometimes convert this to Uncompressed "Wav" because a lot of programs won't know what this is for some reason.
I've found lots of compressors only work right when you do plain WAV --> Compressed, rather than trying Compressed --> Compressed Differently.
I hope I understood the problem right...
Make LG DVX-286 (/ DVX-276) region-free
By joniakaidiot in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Mar 2010, 08:33 -
Audio problems with RJTech 1500 DVX II
By whenloverageswild in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jan 2008, 12:36 -
LG 298h DVX subtitles problem
By gorica in forum DVD & Blu-ray PlayersReplies: 3Last Post: 28th Nov 2007, 12:43 -
DVDFab Platinum generic.xvid.mp3 audio problem
By JoeWillis in forum DVD RippingReplies: 0Last Post: 29th Aug 2007, 19:59 -
DVD to AVI[Xvid] Audio Problem
By Kapnos in forum DVD RippingReplies: 14Last Post: 20th May 2007, 01:46
