I have few movies in Mpeg4 format which I would like to watch on my standard DVD Player. How would one do that ? Do you have to re-encode it to Mpeg2 which means file size will grow
Morning prasadkulkarni,
yes, you have to re-encodeI have few movies in Mpeg4 format which I would like to watch on my standard DVD Player. How would one do that ? Do you have to re-encode it to Mpeg2 which means file size will grow
and, yes, file size will grow. But, at least they will encode much quicker,
than if you had to encode your own captured AVI's.
What's the resolution size of those movies, ie, are they n X 240 ??
ie, 320x240 or less ??
or, are then over n X 240 ?? ie, 300x290, 640x300, 512x298 etc. ??
Also, while I'm at it, I've post a small sample. You can check it out (look
below), and let me know if it compares (not likely) to those movies's you've
D/L'ed (obviously) - - and they're divX (a.k.a. MPEG-4)
Thanks.
-vhelp
VHELP's Samples ...last 11.16.2002
Mpeg4 in WMP11
By Beaker14 in forum AudioReplies: 13Last Post: 5th Jul 2012, 18:10 -
MPEG4 to AVI
By Jomapil in forum Video ConversionReplies: 2Last Post: 30th Mar 2012, 15:55 -
dvd to mpeg4
By dvdnewbie64 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2009, 18:18 -
Mpeg4 to ?
By acestu in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2008, 21:45 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 30th Oct 2007, 23:47
