I downloaded Monsters Inc, and it is 1h32m long... it won't of course fit a 80min CD.
Is there a way I can - I don't know - compress it a little more so it would fit?
thanks
Results 1 to 9 of 9
If your player supports it you can make an XVCD with a lower-than-standard bitrate. Lower bitrate gives you lower quality, but on some material it's still acceptable.
If you're one of the lucky few you can also try making an XVCD with VBR to try to have better quality in the same space. A lot of players don't support VBR MPEG-1, though. -
you could use kwag's templates. you can fit 120 minutes on a single cdr. www.kvcd.net
Ok... I downloaded some templates... I'm encoding as I write this...
only one more question: should I burn as SVCD? Cuz I chose a 320x480 template... and this is not VCD format right?
I think my player (Panasonic RV32) has some "issues" with SVCD. -
From what I have read, it should be burned as a non-compliant vcd. Ive used Nero for similar projects, Nero will alert you to this non compliancy and give you the option of continuing the burn.
i too have "issues" with svcd. what i do is change the header of the mpeg2 to mpeg1. then i burn the disc as vcd 2.0. works perfect.
I encoded a 90-minute movie using XVCD, bitrate about 1000b/s, the file size is about 740MB. When I use Nero to burn in non-compliant VCD, it won't burn because the file size is greater than 700MB on a CD-R 80. Do I miss something here, CD-R 80 can store compliant VCD up to 800MB file size, how come it won't accept file size > 700 MB for non-compliant VCD? Did anyone use Nero to burn file size > 700 MB ok?
Originally Posted by cdechery
my dvd player (apex 1200) wont play that reso.
i usually use KVCD templates and change the resolution to 320x240
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
best minimum size for a 1080p 90min movie
By renfr in forum Blu-ray RippingReplies: 8Last Post: 20th Jul 2011, 02:55 -
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 19:32 -
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 06:31 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 16:12
