  1. Can any one help me, i have CCE 2.66 and use it convert Divx to SVCD over two discs, however now i have 2.66 there is a green bar at the top of the encoded image about 3cm deep, and a block of squares in the right hand corner. CCE2.5 used to work fine, but now produces the same results !!!. Help.
    Thanks in advance.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    Elecard MPEG2 codec. It puts that nine box watermark in upper corner.
  3. Thanks, but i dont think i have installed that codec, if i have how do i check and how do i remove ?
  4. Thank you, i will give it a try asap.
  5. I have got that software and the codec is not on my system, anyone know of another reason why i might be getting a blured image and a green bar at the top ?
