I have VirtualDub 1.4.11 (build 14279). No matter what Divx file I load, the file information will show it as 23.976 fps. However, several files I've then loaded into TMPGEnc to convert to SVCD are really 29.97 fps. I've discovered that through the TMPGEnc Wizard, when I try to use the SVCD (NTSCFilm) template, it needs to do an inverse telecine and pulldown to make the file 23.976. I've then backed out, chosen the regular NTSC mode (29.97 fps) and encoded the film, it works perfectly.
Why is VirtualDub giving me the wrong information? It didn't used to do that, it was very reliable. I've used VirtualDub/TMPGEnc to reencode dozens of Divx files to SVCD with no problems up until now. I've even encoded a movie as 29.97 fps, loaded it into VirtualDub, and it says it is 23.976 fps. Very odd.
Using WinXP Pro, have Divx 5.02 Professional, TMPGEnc Pro 2.58 (now 2.59), all requisite codecs installed.
Results 1 to 1 of 1
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
Avi showing wrong length. Encoded with virtualdub
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 3rd Nov 2011, 12:06 -
VirtualDub cut .avi at "wrong" place!
By larsli in forum Video ConversionReplies: 10Last Post: 17th Sep 2010, 08:25 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Virtualdub - What did I do wrong?
By tigerb in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2008, 11:42
