I used Pegasus PICVideo MJPEG Codec with VirtualDub and tried to capture a recording from an old videocam (8mm). The quality of the picture is great when it's showed in VirtualDub but the captured file is not the same.
The captured files are a bit slower and has a irregular "flow" when looking on them in Media Player, and in Adobe Premiere where I want to edit them. The files are as slow even after I have exported them to a MPEG-2 file from Premiere.
I capture without sound and have tried with both quality 19 and 20 but it's all the same. My card is a Sparkle Geforce4 Ti-4200 VIVO. I use Windows 2000 + SP3, Amd 1800+, 256 Ram and two harddrives (one for windows and one for captured files).
Any ideas what the problem is? I have used a Matrox Marvel G-200 and I never had any problems to capture files so can it be because that the Geforce card is bad?
Sincerely,
And69
Results 1 to 1 of 1
How to make dv captured files smaller and easier to stream?
By videomav in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2011, 13:22 -
cannot burn or copy captured mpeg2 files
By DirtBikeMike in forum Capturing and VCRReplies: 12Last Post: 3rd May 2011, 08:49 -
why does Avidemux play back files faster or slower
By mukluk909 in forum EditingReplies: 1Last Post: 2nd May 2011, 13:26 -
Hi8 captured DV to MPEG2 or x264 MKV files
By pred02 in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 16:09 -
De-interlacing video captured from a standard AV source
By Garblefunk in forum Newbie / General discussionsReplies: 33Last Post: 4th Jan 2009, 07:49
