I am trying to make a SVCD from an AVI file using TMPGenc. I have used Tendes's SVCD Encoding guide. Rate Control Mode is CQ, setting is 80. DC Component precision is 10 bits. Motion Search precision is High quality (slow). I left all the other options as they were.
After the conversion to MPEG2 I used VCDEasy to create a bin/cue file. Then I used CDRWIN to create my SVCD disk.
I am not satisfied with the end result. When I play the movie there are "blocks" on my TV at some parts of the movie. And at some part the movie is not smooth, it is bit jumpy (don't mind my English please)
Is there a way to correct these problems?
2 ideas come to mind that might help,
1) burn your movie at a slower speed and/or with a different cd burner program,
2) re-encode the AVI file using different settings.(CQ is not as good as VBR however CQ is quicker)
its also possible its native to your AVI file, are those blocks there at the same point in the original AVI movie? if yes then unless you can find a different copy of that movie those blocks will always be there.
look around on the site,plenty of info everywhere
ciao
TLTwThe Hellsing family will purify this world... -
Burning at a slower speed solved the 'blocks' problem. Thanks!
Now I will try to solve the jerkey part. It is not that jerkey. It is very subtile. Maybie I am to demanding
Glad I could help
the jerky motion your talking about might be caused by strange frame rates, however this is just a guess, I get a jerky motion usualy when the screen moves from side to side slowly, can see the picture jump a little every second or so. Which I think is caused by frame rate convesion.
I have gotten this even when i have ripped from dvd, not sure how to fix it though.
ciao
Sometimes, jerky motion can be caused by selecting the wrong field order.
Hope That Helps!!!
:P
AVI-video very choppy in preview but smooth in trimmer
By JackDalton in forum EditingReplies: 3Last Post: 28th Nov 2010, 20:21 -
Uncompressed AVI to WMV @ 30fps cannot seem to get smooth video...
By neilcooper33 in forum Video ConversionReplies: 23Last Post: 21st Sep 2010, 16:25 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
Cannot get trimmed a DV-AVI movie in MS Movie Maker
By askmaxim in forum EditingReplies: 0Last Post: 30th Dec 2008, 06:44 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37
