Hi everyone,
i'm new to this forum and playing with video in general![]()
Guess i choose the right part of the forum huh?
Anyway here's my question.
I downloaded a wmv clip online, rare, rather short (3.900ko) but of a poor quality.
Suspecting than converting from a format to another never make things better i wonder if there's a way to make improve the quality of that file.
Is there a software that could help or even a converting setting that would work?
thanks in advance.
The best you might be able to do is this:
1) convert the WMV to AVI (tips in the convert section or if you get the MS XP Movie Maker Beta 2 you can convert it to DV AVI or use asftools).
2) Load the AVI in Virtualdub and try applying filters to the video to try to clean it up. You will never achieve super quality but if there is noise or bad color you can compensate.Panasonic DMR-ES45VS, keep those discs a burnin'
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06 -
wmv file
By pcb in forum Newbie / General discussionsReplies: 14Last Post: 11th Aug 2008, 19:20 -
how to cut a wmv file
By stranzer in forum Video ConversionReplies: 5Last Post: 22nd Jun 2008, 12:26 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 19:19 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 23:06
