I am capturing from my Sony D8 to a compaq notebook with PCMCIA firewire card. Capturing (with a Ulead module) works o.k. When I look at the captured avi file later using Media Player, there are no dropped frames (also visually the scenes are o.k.). After conversion to either MPEG-1 or -2 at any resolution the generated MPEG files, viewed again with Media Player, look jerky (noticable during movements of camera or objects in the scene). Again: The original avi file does not have this problem! This is independent of the chosen data rate. Any hints? Thanks!!
Results 1 to 1 of 1
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Finding dropped frames in captured avi
By vhelp in forum EditingReplies: 4Last Post: 14th Jun 2010, 05:24 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Captured AVI frames broken/split/badly aligned
By cyclometric in forum Video ConversionReplies: 3Last Post: 25th Sep 2008, 07:50 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
