I figure someone have done this before but I post it again so new person can learn:
- set up TMPEnc w/ your settings
- go to setting-advanced and select the source
range to pick your start frame and end frame
- save the project
- repeat these for next MPEG files (with different
start and end frame, of course)
- finally, load all the projects and do batch encode
I think this is better and faster than encoding the whole AVI and cut it later. I also had a problem of using TMPEnc cut, the file becomes 2.0 non-compliance under Nero after cut.
Hope this is worked for you...
Results 1 to 1 of 1
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
How to go from DVD to small MPEG file
By jester805 in forum Newbie / General discussionsReplies: 10Last Post: 17th Oct 2008, 19:15 -
Multiple home video clips... One giant AVI->MPEG encode or break it up?
By binister in forum Video ConversionReplies: 1Last Post: 14th May 2008, 13:59 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
