I know that i can import in "wav" format dts/ac3 soundtracks and keeping the 5.1 format.
I ripped a dvd (the music part) and i have an .ac3/.dts file
How do i convert it to wav so that i can burn it to cd keeping the 5.1 sound?
Besweet will convert an AC3 to 6 wave files, BUT -
It will not play on SVCD or VCD in that format - you can convert to Multichannel Mpeg but most players and amps are not compatible. You could make MiniDVD but same compatibility issue. Best choice is Prologic 2 encoding, which BeSweet will do.
Now if it is just audio, you can burn the AC3 to CD and apparently it will work as audio only. -
i am interested in audio cd only..............
So i have the following questions:
1) Besweet is a standalone programm?
2) It can decode dts as well?
Thank you -
BeSweet is a GUI for TooLame, Azid and several others but comes packaged with most of them. Not sure if it handles DTS.
BeSweet is another hideous kludge front end that I wouldn't pay 5-cents for because it is unintuitive, stupidly-designed, and just plain broken.
You can try a program called HeadAC3he. It will create a wav and you can leave 6ch or downmix to 4 or 2 channel. Some people have success with it and others not so good. I have not used it for creating just cd audio. It works good for me to downmix dolby ac3 to 2 channel surround for svcd. I am not sure if it will convert dts.
BeSweet is another hideous kludge front end that I wouldn't pay 5-cents for because it is unintuitive, stupidly-designed, and just plain broken.And yes...we all wear wooden shoes here in Holland...
My TV doesn't run either .DTS and .AC3 file from .MKV movie
By galodoido12 in forum AudioReplies: 2Last Post: 3rd Feb 2012, 23:29 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
DVD main title to single file, with AC3/DTS
By knight76 in forum DVD RippingReplies: 5Last Post: 27th Feb 2009, 10:30 -
VOB DTS file to VOB AC3
By shanthaprasad in forum AudioReplies: 4Last Post: 25th Sep 2007, 13:34
