hi to all!
im a newbie in this ripping thing. its a promising hobby but the first movie i ripped seems to act abnormal.![]()
ok after i rip a DVD - VCD.. my movie moves faster than normal.. its like you are forwarding the movie.. though its not that fast but still the characters act like a "Charlie Chaplin movie-kindda-thing".
i use >smart ripper v.2.41 > DVDx 1.8> VCDeasy 1.0.9 and the movie is still on my harddrive ready to burn in Nero.
anyone knows what seems to be my prob?
Results 1 to 9 of 9
VCD, DVD, whats next?
If you want fast , reliable, DVD-VCD use eazyvcd from www.eazyvcd.tk Its an all in one program, very simple.
i use dvddecrypter, dvd2avi and tmpgenc to rip and encode and nero to burn, with superb results
I think you all misunderstood the question. His question is why the movie moves faster than it should be. Probably, you ripped and encoded with different frame rate.
I don't use DVDx. I cannot help you with that. I use Smartripper->DVD2AVI->Tmpgenc so that I can have full control in each step.
...so can you show me any tutorial with your prefered utility softwares? a link also to said softwares will bw of much help cause i dnt have any of them except of course for the smartripper.
thanks -
press, you might want to follow this online guide
http://www.vcdhelp.com/sefy/
and the programs i use are smart ripper, dvd2avi, and tmpeg as mentioned above by others. and also something to burn them with.
hope that helps
Are these lines normal?
By Abas-Avara in forum Newbie / General discussionsReplies: 12Last Post: 18th Oct 2009, 11:41 -
Convert .ts to something normal
By Akkira in forum Video ConversionReplies: 10Last Post: 21st May 2009, 18:05 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 00:36 -
Normal encoding
By mrgorgeous in forum ffmpegX general discussionReplies: 4Last Post: 5th Oct 2008, 17:42 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21
