I am going nuts trying to figure something out. I have encoded an AVI to VideoCD NTSCFilm format using the latest TMPEng. I can play the mpeg file on my computer and hear sound, I can use Nero 5.5 to burn a VCD and play that in my cd-Rom and hear sound, but when I put it in my stand alone DVD player. The movie plays, I see an image but hear no sound. Has anyone had this problem? if so what can I do to resolve this
Thanks For the help
I have the same when playing SVCDs on my Marantz DVD player. If you have a Philips it may be the same because my Marantz is basically a Philips in a different box. The workaround is going into setup of the DVD player and change "Digital Audio" from the setting "All" to "PCM only". Then I have both audio and Video. When watching a DVD I return to the "All" setting to enjoy Dolby Digital et al.
Hope this helps.
Regards,
Willem -
thanks much that got me a solution. I ended up having to turn digital sound off entirely. PCM only didn't work. That gave me a direction to look and at least I was encoding and burning properly.
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12
