Help!
Trying ot find out why VirtualDub and TMPGEnc showing different
frame type and total number of frames of DIVx files.
Example: VirtualDub showing 23,976fps and 132476 frames.
but TMGEnc in Source Range window shows 30fps and 165760 frames.
Which settings should be used when encoding to XVCD with TMPGEnc?
Seems like it does make difference in fast motion scenes (interlacing artifacts).
Any information would be greatly appreciated! Thanks.
Results 1 to 1 of 1
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 03:12 -
increase the frame width with virtualdub?
By sharmine in forum Video ConversionReplies: 3Last Post: 17th Sep 2007, 18:17 -
image shift in frame with Virtualdub capture
By Knightmessenger in forum Capturing and VCRReplies: 0Last Post: 27th Aug 2007, 01:16 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 13:28 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 12:15
