nothing is wrong wit my dvd, every 10mins the dvd skips further into the movie, this is VERY FRUSTERATING. i burned 3.9 GB onto a 4.7 GB dvd-r using nero, anyone please suggest sumthing.......
Results 1 to 12 of 12
What's your DVD media brand? and what software did you use for authoring? Maybe cheap media problem.
im used dvdit to author it, nero to burn, uhhh nero 5.8.8 or sumthin like that
in nero when i was burning, i UNCHECKED the finalize Cd box, i only checked the write cd box, does that have anything to do wit it?? by the way, i used claddvd
have you tried playing the dvd that you've in the computer to see if it played correctly??? whant kind of dvd media are you using?? is this the first time you are using that media???? try using a dvdrw so you don't waste a lot of media... try using recordnow max or gearpro dvd to burn it....I used to use nero and I have problem so I tried gearpro and recordnow max and it works better for me
just my 2 cents -
I believe you should check the finalizing box. You can't play DVD in settop player without finalizing the disk.
i have recordnow DX, it doesnt let me burn dvds, im burning this to a DVD-R, this is actually like my first time trying to make a DVD. i am using a Pioneer DVDRW 104 to burn them and it is with nero. tell me every info u guys need so i can solve my dilemma
when u burn ur VOB files with nero, do u select DVD-VIDEO in the beginning, or DVD_ROM(ISO)?????
try downloading the driver update ...I have to do that to make my drive recognize by recordnow max..
i wrote on this a couple of weeks ago and somebody said it was the media.... and they was right for a min.... it did it on the cheap media but not my apple media.... but now (in last few days) i notice it started doing it on my apple media now.... it do it in da xbox but not ps2.... i havent tried my portable yet..... whats going on?????
DVD skipping on certain players...
By Lewshu in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2011, 23:35 -
DVD skipping for Client - tried everything we can think of!
By trevmarps in forum Authoring (DVD)Replies: 15Last Post: 2nd Apr 2010, 15:46 -
Skipping a menu on a DVD
By Luriden in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2008, 22:03 -
DVD keeps skipping!
By Variable in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 18:05 -
DVD Player Skipping
By WuPhilly in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2008, 10:33
