Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Nov 2002
    Townsville Australia
    Is there any way I can burn movies I have downloaded from the net to cd and play them back through my PlayStation 2? Do I need to get my PS2 Mod chipped? Or is there no way I can do this??? What about X-Box, can it be done for X-Box???
  2. For movies in DVD format, no modchips is require to play it on PS2. Problem is I still haven't found a media that work well with PS2 for movies. DVD-R media i used work fine for PS2 games but not for DVD movies.
  3. You can burn PS2 games? How do you do that?
  4. Maybe you should try Samsung's BeAll media. It says it is compatible with PS2. You can get it from http://www.meritline.com . I haven't tried it yet, but I might get some soon.
  5. I've used "LEDA" aka "Princo" DVD-R media (real cheap stuff), and had no problems with my PS2.
    I also tried DVD-R/W but it couldn't read that.
    There are several different flavors of PS2, i have a "version 4".
    Check "the Ghost's" user comments in the "DVD Players" section for a rundown of the different versions.
  6. I also use Prince ones with white top. movie kept freezing and jumping on PS2, i have version 5 ps2
  7. I don't think all of The Ghost's information is correct. I have version 2 according to him, but it won't play the DVD-RW that I made.
  8. Your solution,
    Burn with Prassi Primo DVD 2.0
    Use Verbatim Datalife Plus as your media.
    Your DVD-R films will now play and also copy games on your playstation 2 if (chipped) perfectly. 8)
