HI,
I have a 830Mb file that I want to burn to a CD. Since this will exceed the disk capacity, I need to split it.
I am using MPGENC to do the split, but it only does a couple of hundred megs and it stops. I assume that the file has to be fixed some how, but how, and what tool?
Any thoughts?
Results 1 to 20 of 20
You can try using the splitting tool in TMPGEnc (Files --> MPEG Tools --> CUT/Join )
Regards.Michael Tam
w: Morsels of Evidence -
I assumed he was, but had forgotten the TOriginally Posted by vitualis
instead of using up 2 cds... you could fit it on 90 Min CDR.. 1 90 min cdr shouldnt run you too much $$Originally Posted by shubb
Ah.... Perhaps he is. For a moment I thought that MPGEnc was another product.
Regards.Michael Tam
Hi,
Yes, I have been using TMPGENC (sorry for the confusion). In my version though it is merge/cut, that is the same as cut/join, right? -
have you tried VirtualDub?if there is a problem with the avi,you can check it(file>open file>check the box popup....and i think you check re-derive...)
most of my cutting i have to extract the wav anyway,which VirtualDub does.
if there is no need to extract the wav file "avichop" is the easyest way to cut it in half. http://www.divx-digest.com/software/avichop.html
if there is part of it corrupt go to the tools page(tip:if you try to fix it copy the file somewhere since it may not copy the file(like divxfix) -
Hi Everyone,
Still no luck splitting a big MPEG file. I thought I would try a 90 min CD but it was not big enough.
I have tried splitting the file with TMPGENC but after a certain point the video stream is bad. Any suggestions?
Thanks... -
[quote="shubb"]I thought I would try a 90 min CD but it was not big enough.
quote]
you said the MPEG was 830Mb. a 90min CDR should hold 900MB in MODE2. I believe your burner must support overburning to utilize 90min CDRs tho.. Perhaps your CD burner doesnt? -
Hi,
Thanks for the reply. Bear with me, what is MODE2?
The actual file size is 816mb. -
i couldnt really tell ya the technical definition, all i know is that when you burn a video cd (svcd or vcd) its burnt in MODE2. and at MODE2 you get 10MB per MIN of the CD
74MIN CD = 740MB
80MIN CD = 800MB
90MIN CD = 900MB -
Yes, I find it odd too. The file is supposed to be 816M and my blank CD is 850m, so something doesn't add up.
I use Nero to burn and once I drop the file in Nero says that it is "not a MPEG2, needs to be re-encoded" or something like that. I try letting Nero recode it, and still the file is too big.
Any thoughts?
Thanks -
When Nero tell yous that, its because its not a standard (s)VCDOriginally Posted by shubb
when it re-encodes it, its prob making it bigger..
i would hit the turn off standard complience button
then burn.
Nero wont attempt to re-encode it, but there is a chance your DVD player wont play it then.. worth a shot tho -
Ahhhh, I'm ahead of you. I tried that but still the file is too big.
Figure I'm beat?
Thanks -
if you go into the preferences of NERO, you will have an expert tab, on this tab you will see a check box for overburn, i believe.
then try upping the time to 90 min for your 90 min cd
then try burning again -
I'm using ULEAD MF for authoring and burning and MF lets mpeg-2 up to 815MB to be burned on one 80-Min CD.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
Having problems trying to split MPEG-4 file
By Xax in forum EditingReplies: 7Last Post: 4th Dec 2009, 17:27 -
Best way to split an MPEG file is to ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2009, 21:31 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00
