in the experts opinion... what's the best way to get the best image/sound? (free, that is). any template, or special configuration anyone use? i'm using virtual dub, TMPGEnc and vcdeasy.
tried a lot of examples, including the ones in the tools section, but every one looks pretty the same.
take care!
DVD-R 720x576 PAL MPEG2 9000kbps
Well, what source, and how do you encode it? Plain VCD? ... I capture v'dub/mjpeg from DVB, then encode to CVD. Anything better is overkill, as it's quality is alreadu better than my DVB's signal already...
TMPGEnc has one of the best MPEG2 alogorithyms available anywhere, and that includes expsensive proffessional software. In fact, you will not find better output anywhere. There is no difference, quality-wise, between TMPGEnc and high-end professional codecs such as Ulead, Panasonic, etc.
I have tried all of them, and only TMPGEnc is the only one that gives you the full range of options that the serious encoder must have. In short, don't worry about it: if you are using TMPEnc, you are using the best encoder.
VLC Player: no image, only sound
By gracie283 in forum Software PlayingReplies: 23Last Post: 15th Mar 2017, 11:50 -
PowerDVD 10 - Blu-ray sound OK, menu navigation OK but no image
By rilopes in forum Software PlayingReplies: 4Last Post: 10th Aug 2010, 10:16 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Have image but no sound
By ralphy in forum AudioReplies: 1Last Post: 13th Sep 2007, 23:53 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
