Hi, I followed the "Best Way To Convert a 320x240 Low Bitrate DivX to VCD" but when the encoding is done I check the file and I get an 800mb video..I don't think its exactly normal considering that I'm encoding at 1150 and the video is only 23 minutes long. Anyone have any ideas? Thanks.
Well that 800 MB MPEG1 will fit on a 700 MB CD since VCD is burned in Mode 2 using smaller sectors. As for the size vs. time I am not sure why.
Panasonic DMR-ES45VS, keep those discs a burnin' -
A 23 minute video should only be around 230 MB if it was encoded with VCD specs. So if it's 800 MB the bitrate must be higher than 1150kbps. What did you use to encode, TMPGEnc ? Did you use a VCD template
I didn't use a template, I just unlocked all the settings, and configured it according to vcd standards but changed the aspect ratio to 1:1{VGA} aside from that, the size is 352x240, and bitrate is set at 1150...
Try using the VCD template, because for the file to be that size the bitrate has to be higher than 1150
Have you tried playing the resulting mpeg coz a lot of divx's are encoded with VBR audio. Tmpgenc doesn't like this and gets all confused about the video length, usually extending it greatly, encoding a load of blank video onto the end of the file.
If this is the case, extract the audio from the avi with virtualdub, convert to uncompressed PCM and use that as the audio source when you encode.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 22:44
