I have been using SmartRipper to rip DVD's and have come across a movie, Harry Potter, that is giving me trouble. I read a post somewhere a while back that said if one does not work try the other, ripping programs that is. So I was going to try DVD Decrypter but I get errors that they are no aspi layers and my device not found. I have tried 3.0.0.1.3 from Sefy guide, no luck, and I have also tried a variety of others from version 3008 to 30017, with no luck. I downloaded 2.4 from Doom9 and that worked. Can anyone tell me why the other versions wont work? I just did a clean install of Win XP Prof and I installed aspi 4.71 then did the newest 4.71.2 (that is what it is showing when I do the ASPI Check) or whatever it is they are calling it (download folder says 472b2)! Anyway, I am not to familiar with settings in the newest 3.1.3.0 nor 2.4 and wanted to follow the settings from Sefy's guide so I was wondering if anyone can shed some light as to why I cant get the other versions to work, such as 30012 or30013?
Fun in the sun, Oh no my friend, Fun on the sun!
i'm running xp pro and had to install win aspi 32 to get dvddecrypter to work
im running xp pro and had to install winaspi 32 from adaptec to get dvddecrypter to work, you might want to try that. failing that do a google search for "forceaspi"
Contrary to popular belief, I still recommand ONLY the ASPI v4.60 Build 1021
even to be used on 2000 and XP, it's the only ASPI so far that doesn't cause
problems.
IGNORE the warning on Adaptec's homepage, i've personaly tested this ASPI
on 2000 and XP and it works GREAT.
Notice how many and how fast they keep releasing the v4.70 builds ? they
are simply FULL of bugs and cause major havoc on systems.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Victor DVD player hacks, no where to be found?!?!!?
By hiko in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Dec 2010, 22:55 -
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53 -
Still haven't found a DVD ripper that can...
By tahoma in forum Newbie / General discussionsReplies: 4Last Post: 10th Sep 2008, 07:34
