I have an Anime DVD the contains 6 episodes,
VTS_02_1, VTS_02_2 (Eps #1)
VTS_03_1, VTS_03_2 (Eps #2)
VTS_04_1, VTS_04_2 (Eps #3)
VTS_05_1, VTS_05_2 (Eps #4)
VTS_06_1, VTS_06_2 (Eps #5)
VTS_07_1, VTS_07_2 (Eps #6)
I will be using Rempeg to encode my dvd cause I am a bit familiar with this program.
Yesterday when I try to encode this dvd it finish in about 1 hour. So obviously it did not encode the whole dvd right? It ended up to be about 1 gig so I'm assuming it encoded maybe one or two episodes.
-In the notpad for "Sample.cffl" that came with Rempeg, I edit it so it can look like this.
CFFL
F:\Robotec\Robotech 1\VTS_02_1.VOB
F:\Robotec\Robotech 1\VTS_02_2.VOB
F:\Robotec\Robotech 1\VTS_03_1.VOB
F:\Robotec\Robotech 1\VTS_03_2.VOB
F:\Robotec\Robotech 1\VTS_04_1.VOB
F:\Robotec\Robotech 1\VTS_04_2.VOB
F:\Robotec\Robotech 1\VTS_05_1.VOB
F:\Robotec\Robotech 1\VTS_05_2.VOB
F:\Robotec\Robotech 1\VTS_06_1.VOB
F:\Robotec\Robotech 1\VTS_06_2.VOB
F:\Robotec\Robotech 1\VTS_07_1.VOB
F:\Robotec\Robotech 1\VTS_07_2.VOB
Then I saved this file and launch Rempeg and load the sample.cffl
After all the setting was done in the "Option" tab I press encode and everything seem fine till an hour later. Why did it stop encoding so quick? Do I have to encode each episode seperatly? I would be so confused if I had to encode each one seperatly. The whole DVD is about 6 gigs. I just want it to fit on a DVD-r 4.3 gig. Is there a better way of doing this?
Thank you for your time....
Results 1 to 1 of 1
Removing Trailers from a 4.9GB DVD to fit in a 4.7 GB DVD+R
By rotchild in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2009, 19:20 -
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 21:42 -
shrinking a dvd so it can fit on a regular 80mb dvd instead of dl
By funkymonk in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2008, 17:22 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 12:46 -
How to burn DVD files that don't fit on DVD?
By aqualung2003 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2007, 01:43
